Kay01's avatar
Kay01
Nighthawk x4s
Extender was working great for 8 months but now no longer working. Only light on is power. I have reset but still nothing. Can't recognize router now which is a cisco. I have not changed any settings.
Original set up was a nightmare but Netgear was able to help out. No longer under warranty and they want $90 to help.
  • plemans's avatar
    Are you trying to reinstall it using the wps method of install or using the smart installation wizard?
    I'd highly recommend setting it up via the installation wizard when you're using a router from a different manufacturer.
    • Kay01's avatar
      Kay01
      Can't locate the smart wizard. Do you have a link. I did the guided assistance but still can't connect.
