L24
Mar 20, 2017Follower
Password for network does not work on extender
I recently bought a NETGEAR Mini N300 Mbps Wi-Fi Range Extender with External Antennas (Wi-Fi Booster) (EX2700-100UKS) from Amazon. It has connected fine to our router but when I input the router ...
DarrenM
Mar 24, 2017Sr. NETGEAR Moderator
Have you tried to log into the extender settings by going to www.mywifiext.net and then change the password?
DarrenM
schumaku
Mar 25, 2017Guru - Experienced User
Had configured the extender to use the same password for it's local AP like for the connection to the router?
Depending on the router or access point used, it might be possible that there were "unlucky" alphanumerics used for the SSID and/or the password. Some vendor products seem to allow using UTF8 encoded characters, but not all clients take these the same, and break the double byte characters into two - with any random effects. Stick with 0..9, A...Z, and a..z for SSIs and passwords.
