Trelawney7's avatar
Trelawney7
PL1000 and EX6100 AC750
I have just purchased a PL1000. Will it create a wifi hotspot, and/or can my EX6100 AC750 create a hotspot, or do I need the PLW1000?
    • Trelawney7's avatar
      Trelawney7
      Awesome thanks.
      We have a number of different circuit breakers on our property. There was nothing to suggest this would be an issue when I purchased the PL1000, but now I’m led to believe it is?
      • plemans's avatar
        Potentially yes. Things that degrade powerline performance include surge protectors, arc fault circuits, gfci circuits, high draw motors on the same line, some cell phone charges, houses with old wiring, all these can reduce the performance.
        Its not saying they won't work but like any electronics transmission, the further away/more obstacles/more interference, the worse the signal.
        Its still a hardwired connections so the nice thing is if you have signal and get a decent speed, its usually always that speed baring adding further issues on the circuit. I prefer them to wireless extenders for this reason. If you already have the powerline devices and extender, I'd try them out working together.
  • Thanks. I’m getting an unidentified network/no internet when plugged into the second PL1000.
    Haven’t tried the extender yet as need to get a useable connection on the Powerline?
    • plemans's avatar
      Setup the powerline devices in the same room first. Just to get everything connected and working fine. If you can't get them setup in the same room (aka same circuit) then either something is wrong with them, they're hooked up wrong, or something is seriously causing interference in your wires.
      Once they've established connections with each other they basically work as a ethernet wire.
