maddavo
Jul 31, 2015Tutor
EX7000 Virtual MAC Address problems
I want to disable the EX7000's allocation of virtual MAC addresses to devices on my network but I cannot find anywhere how do do this. I am coming to the conclusion that it is not possible. The vir...
netwrks
Aug 03, 2015Master
Yes, that's what the EX7000 and other extender's do. You can't remove the virtual mac address function. Not sure if it's an option for you, but the EX7000 does support AP mode.
maddavo
Aug 09, 2015Tutor
No, AP mode is not an option - no wired network at the EX7000 location.
So in summary, there is no solution to my problem. Virtual MAC addresses cannot be turned off so there is no way for the DHCP server to allocate the same reserved IP addresses to wireless devices across the Wi-Fi and extended Wi-Fi networks. Either each wireless device must be set to manual IP address (not using the DHCP server) OR the DHCP server has to have two IP addresses reserved for each device.
