thowoc's avatar
thowoc
Security configuration
Just configured the extender and it works fine BUT only if configured with no security.
If I configure it wirh WPS, I cannot connest to the network, getting the error code/answer "Unable to connect to the network".
I run Windws 10 Pro, version 1607, OS Build 14393.105
Any advices?
Thomas
  • Hello thowoc
    I would make sure your router is set to WPA2 security and then factory reset the extender and try to do the extender setup again.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello thowoc
    DarrenM
    • thowoc's avatar
      thowoc
      Hi Darren,
      Thanks for your answer.
      I've got it working after reset.
      However, using the same password as the router didn't work.
      I had to change the set-up to another password and it works now.
      Thanks again!
      Thomas
