HyImTim
Jan 02, 2018Aspirant
Setting up EX7000 access point without wiring it to the router?
I’m not too tech savvy but from what I read you set the EX7000 up as an access point and connect it to the router using the Ethernet ports. However that’s not what I want exactly. I was wondering if I...
jvasanth1984
Feb 18, 2018Virtuoso
Hi HyImTim,
Yes, you can connect it to the wall jack ethernet port provided there is an internal wiring which will connect it to router's LAN to get the connection from it.
