kk4mds
Jul 07, 2016Aspirant
Unit not connecting
Unit worked for quite some time. Had to replace wireless router with same make and model. Tried to connect unit to network using WPA buttons. Would not connect. It connected to wireless computer, but www.mywifiext.net keeps asking for user name and password. Hae no idea what they would be. Any suggestions?
Hello kk4mds
Since you got a new router I would suggest factory resetting the extender and doing the setup again some setting could be causing the issues.
DarrenM
- DarrenMSr. NETGEAR Moderator
Hello kk4mds
DarrenM
- kk4mdsAspirant
My main problem was that I could not use the alternative method of using the webpage because I didn't remember what the user name and password was. That problem has been solved and the unit is working fine.
Thank you
