JPTECH1111
Aug 31, 2017Aspirant
VUDU App and magicJack App don't work with the EX7000 Range Extender connected to R7000 Router.
Using an Android Samsung Galaxy Sky cell phone: The VUDU App and magicApp (magicjack) don't work with the EX7000 Range Extender with Firmware Version EX7000-V1.0.0.50_1.0.102. EX7000 is connected via Wi-Fi to R7000 Router. Both apps work when the cell phone is connected directly to the R7000 Router. The EX7000 Range Extender Wi-Fi names and passwords are different than the R7000 Routers. Basic Internet and streaming both work on a Toshiba Laptop connected to the EX7000 Range Extender.
VUDU APP ERROR: Can't connect to Vudu! Please check your network connection or settings and try again.
magicApp ERROR: Gets stuck on Connecting, Registering with service. Then receive ERROR: Network connection lost magicApp requires an internet connection to make calls. (3)
This statement is at the bottom of the screen: Make sure you are connected to a WiFi or cellular network. You must be online to use magicjack Version 4.18.900.2 [25619][55755]
Google Chrome opens but won't connect to any website.
Google search opens but does not work.
Sort IT App for Movies does not work either.
OK it's working now. The access control was turned on in the R7000 Router settings. I set Access Control to OFF and now all apps on the Samsung Galaxy SKY Android Cell Phone work through the EX7000 Range Extender.
1 Reply
- JPTECH1111Aspirant
