shanman
Jan 24, 2017Aspirant
website for range extender login broken
The website i use to login to the router seems to be corrupted. Everytime i login to the website i cannot access any of the features. If i right click and say open in a new page or window, half of th...
DarrenM
Jan 26, 2017Sr. NETGEAR Moderator
Hello Shanman
You may want to do a factory reset on the extender.
DarrenM
- shanmanJan 26, 2017Aspirant
Hi darren
I did do a factory reset and now the range extender will not allow me to add my networks back onto the range extender. the login website is completly screwed up and does not allow the changing or adding of any parameters at all.
- DarrenMJan 26, 2017Sr. NETGEAR Moderator
Hello Shanman
Something sounds corrupt in the firmware if the extender is still under warranty I suggest contacting support.
https://www.netgear.com/support/contact.aspx
DarrenM
- shanmanFeb 04, 2017Aspirant
Hi DarrenM
its 4 years old so its out of warranty. Is there any other way to replace the firmware on the unit with something else?
