finluxa's avatar
finluxa
WG302v2 - DHCP server - can't set gateway
I need to use the Access Point to issue IP's (DHCP mode). The DHCP client is disabled in this mode. The wired network point is connected to a router. However, if I assign the routers IP address, the unit locks up. I loose connection and need to force a factory reset to get it back. I even tried the default IP range.
Firmware was updated to the latest (5.2.9)
Wireless Clients need to access services beyond the range of the DHCP server, thus packets need to be send to the GW.
What am I doing wrong?
Settings I have used are as follows:
Advanced IP Settings:
DHCP Server is enabled
Starting IP address: 192.168.1.2
Ending IP address: 192.168.1.50
Subnet Mask: 255.255.255.0
Gateway address: 192.168.1.210
  • you need to use different subnet on WG to dish out IP for client
    looks like 192.168.1.x is your primary so if you want DHCP on AP then use 192.168.2.x
  • Hi. I have the same issue, but i dont know if i fix the dhcp server on a different range. what do i put as gateway? it refuses a gateway in a different range?
  • Advanced IP Settings:
    Starting IP address: 192.168.100.2
    Ending IP address: 192.168.100.50
    this how should look like
    GATEWAY will be your main router
  • Thanks 4 replying but is it normal that I get an error message that this ip is not on the same subnet?
  • without knowing your network scheme and what you are inputing I can tell you what is the issues
