kky29
Jul 30, 2017Aspirant
WiFi Extender Ex6200 AC1200
I have this AC1200 Netgear wifi extender Model EX6200 for quite some time. It has always been a problem in continuous connecting to the 5G EXT network. Every few hours our iphone connection drops fro...
kky29
Aug 04, 2017Aspirant
Thanks Darren for the response. It is possible that this is the reason. How can I know about it for sure? Is there any way that the connected network does not change from 5GEXT option at home. I have another wifi modem. How do I make sure that my iPhones do not connect to anything other than 5GEXT option at home.
Thanks
kky29
Aug 07, 2017Aspirant
Thanks
- DarrenMAug 08, 2017Sr. NETGEAR Moderator
If you do not have any devices that connect via 2.4ghz to the extender you could try the fastlane setting to make it 5ghz only.
DarrenM
- exxtreme76401Aug 09, 2017AspirantAlso note that 2.4ghz has a longer range than 5 GHz. If you are near the max distance it will drop the connection. Try the 2.4 channel and see if this doesn't help with this.
