pennyknap's avatar
pennyknap
Follower
Jan 13, 2018
Wifi extender N300 model EX2700 wont connect to my Samsung tablet
I set up my N300 model EX2700 successfully and connected my Samsung tablet. It worked ok but when I tried to connect the tablet to the extender 2 days later it will not connect. It shows up on my tablet as 'ext', but when I try to connect it says 'cannot find ip address'. The extender is connected to my router, the lights are green. I've tried to contact Netgear but no luck there!
Please help!
  • I am also have the same issue. My Laptop connects as well, continuiously.
      • eddie-kvs's avatar
        eddie-kvs
        jvasanth1984wrote:
        Hi eddie-kvs pennyknap,
                                                       Try to perform network power cycle and check if it works.
        Believe it or not, I'm not a neophyte. I performed a hard reboot on the host modem/router and then powered the wifi extender. Of course I rebooted the Samsung devices and even reset the the devices so that all connections were purged, purged the partition cache just "finger cross" measure. No joy, no connection.
        So what's next... other than elementary steps?
        -Eddie
