Kevelstone
Aug 14, 2018Aspirant
wifi extender not visible on windows 10
Can anyone advise, my new wifi extender is not being detected on my windows 10 machine, i have successfully connected on my linux and android devices but it is not showing up on my windows 10 device
Are you seeing other wifi networks on the Windows 10 system?
- KevelstoneAspirant
yes all other networks are still visible, not sure if there is anything that needs enabling on the network adapter
If the PC is within range of the WiFi then it should be seeing the network. Are you using the normal Windows facilities to connect?
