hhv's avatar
hhv
wn 2000 rptv2 error message saying password is not correct on _ext ssid.
When I enter the correct wifi password from my xfinity home network, (16 digits long) I get an error message saying the password is incorrect. When I connect via the regular ssid (without the _ext) it works fine.  I cannot connect to the _ext ssid to logon and try to use the genie.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    Does the xfinity password use simple alphanumeric characters or are there other symbolic characters used also? Would you mind posting the password here?
    • hhv's avatar
      hhv
      There are only alphanumeric characters used in the password.
      • nhann's avatar
        nhann
        Is this a first time setup for the WN2000RPTv2?
        When setting up the extender to connect to your router, is the security option matching the one being used on your router? (e.g. WPA2)
