Cheiro's avatar
Cheiro
WN1000RP not connecting after changing Wi-Fi channel
Hi all,
I've been running my Wi-Fi extender absolutey fine until I recently changed the channel of my Virgin Media Wi-Fi router (SuperHub) to channel 13, from channel 11.
Now, when attempting to set up the Wi-Fi extender on the new network - whether by WPS or manually - everything seems fine until I try try to connect to the network with my devices. They pick up and log onto the _ext network fine, but then just say 'can't connect to the internet'.
I've tried this on Android and Windows 10, all with the same result. Any ideas appreciated!!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Cheiro
    Have you tried to forget the extender network on your devices and try to reconnect and enter the wireless password again?
    DarrenM
  • Hi Darren,
    No I didn't consider it could be the devices rather than the extender! Thanks - I'll give that a go and report back :-)
  • So I've 'forgotten' the network and reconnected on several devices, and I'm still getting the same 'unable to connect'. The lights on extender are showing its connected to the main network. Any ideas?!
  • Free bump!
    I'm having a similar problem (as are clearly a great meany other people...) and I posted about this as well.
  • Thanks for the free bump oliveview! Did you find a solution?
    It just seems bonkers to me that there's no helpline - you have to pay for customer support. I've not been able to find a fix for this issue in over two weeks of scouring the internet!
    • netwrks's avatar
      netwrks
      Master
      Just Reset the extender to factory default and try again..
      • oliveview's avatar
        oliveview
        Tutor
        This is something I have done way too many times, to no avail. It'll work again for a few hours, then by the next day it's back to not providing Internet access to all of the very many wirless products in our house.
      oliveview
      Tutor
      Sorry, I have no solution, whatsoever. At this point, I'm left to look into buying a new router (obviously, not a Netgear). I've turned off, reset, tweaked, moved, etc my Netgear router more times than I can count now. Considering that this issue is a common one brought up in these forums, and on the web in general, it seems clear that it must be a product defect.
      I also agree, the lack of non-pay support is a deal killer.
  • Likewise netwrks - resetting the extender is the very first thing I tried! Looks like this is a product defect :-(
  • I hear you oliveview... In light of what others are saying on the forums, I think it's time to try a different product - one with even just a basic level of support would suffice!
    • DarrenM's avatar
      DarrenM
      Hello Cheiro
      I would make sure you are on the latest firmware, have your router set to the best channel and do a factory reset of the extender and may try to re position the extender if you can.
      DarrenM
