CPBPMILL
Feb 07, 2016Aspirant
WN3000RP and BT Home Huib 5 not seeing eachother
Hi all, Have an old WN3000RP ranmeg extender (an origional one I giuess, as no V1, V2 etc extensions to its name) which has always managed to automatically change its address whenever I have chan...
netwrks
Feb 07, 2016Master
Reset the range extender to factory default and reconfigure.
- CPBPMILLFeb 08, 2016Aspirant
Thanks very much for coming back - using the all importnat bent safety pin have tried that about a dozen times using the 'factory reset' hole. Is there any other way you can think of doing it?
- CPBPMILLFeb 10, 2016Aspirant
Mystery thickens. The WN3000RP configures itself quite happily in the normal way to a Home Hub 4 at another location (have just tested it). So the villain of the piece is the Home Hub 5. Anyone have any ideas on why this particular router doesn't like the WN3000RP?
