CPBPMILL
Feb 07, 2016Aspirant
WN3000RP and BT Home Huib 5 not seeing eachother
Hi all, Have an old WN3000RP ranmeg extender (an origional one I giuess, as no V1, V2 etc extensions to its name) which has always managed to automatically change its address whenever I have chan...
CPBPMILL
Feb 08, 2016Aspirant
Thanks very much for coming back - using the all importnat bent safety pin have tried that about a dozen times using the 'factory reset' hole. Is there any other way you can think of doing it?
CPBPMILL
Feb 10, 2016Aspirant
Mystery thickens. The WN3000RP configures itself quite happily in the normal way to a Home Hub 4 at another location (have just tested it). So the villain of the piece is the Home Hub 5. Anyone have any ideas on why this particular router doesn't like the WN3000RP?
