paradoxsj
Apr 12, 2012Aspirant
WN3000RP believes it has no IP address those status screen says otherwise
If the setup and config isnt bad enough...NOW the device acts as if it has not IP address so when any device connects to it, it has not access.
Logging into the deive under shows it has an IP address and all the other key network setting...
BUT when you connect to the SSID you have "limted access" do to the device not having the IP address that the shows it having.
I am on the latest firmware:V1.0.1.18_1.1.24
Any ideas and thank you in adv.
- jmizoguchiVirtuosoTry putting google DNS on pc side
- paradoxsjAspirant
jmizoguchi wrote: Try putting google DNS on pc side
Thank you.
Still doesn't work. - jmizoguchiVirtuosowhere you able to ping router and google dns?
- paradoxsjAspirant
jmizoguchi wrote: where you able to ping router and google dns?
What does google DNS have to do with my access point connection to my router and getting a IP address?
Yes the router is pingable...in addition, the nework is closed so google DNS does not come in to playl - jmizoguchiVirtuosoif you can ping router then should able to ping external IP
did you ping google or did not even tried? - paradoxsjAspirant
jmizoguchi wrote: if you can ping router then should able to ping external IP
As I mentioned above this has nothing to do with the internet...This is a private network.
Sure I can ping google but what does that have to do with my AP not getting an IP address from it router? - jmizoguchiVirtuosobeen on mobile phone till now
you had static IP set on this pc since you can ping the router correct? Seem very common for extender to not getting the IP fro the DHCP - paradoxsjAspirant
jmizoguchi wrote: been on mobile phone till now
The AP shows it has an IP address when you directly logon to it and look at its status page BUT when you connect to it, it has limted access and says it has no IP adress.
Thus any de - jmizoguchiVirtuoso
you did not answer to yes, no to the questions.when you directly logon to it and look at its status page
assuming you had static IP.. - paradoxsjAspirant
jmizoguchi wrote: you did not answer to yes, no to the questions.
I've given the AP a static address AND I have allowed DHCP to assign it an address. Either way, it gets the same address as this is how my router is configured.
I can ping the router regadrless of having a Static or DHCP assigned address.
