Gab92
Mar 21, 2019Aspirant
WN3000RPV3 cant connect on my windows laptop
Hello,
i've been try to connect the wifi extender to my laptop unfortuanally everytime i try it says "unable to connect" , so i tryed with my mac and it worked . I Really need this to work on my windows laptop and i dont know why it doesnt .
My Mac and Windows laptop are in the same room, my mac get perfecetly connected and my Windows laptop doesnt, i tryed reset and doing the installment 3 times always the same. I checked if maybe the driver where up to date and they were all up to date, the wifi extender has all the lights green. I dont understund why it wont connect to my windows laptop.
I have a Intel Dual Band Wireless-AC 3165 on the laptop.
Could please someone help me?
Thank you
What NG product and model# are you referring too?
Gab92 wrote:
Hello,
Thank you- Gab92Aspirant
i have a WN3000RPV3 - N300 wifi range extender still dont understund why on my mac works but on my laptop doesnt lol
- tlynch833Aspirant
Gab92
Did you resolve your problem? I have the very same situation and would like to know what you did
thanks to you
- Christian_RNETGEAR Employee Retired
Hello tlynch833 - If other devices are able to connect to the extender except your windows laptop, you may need to update your WiFi adapter driver on your windows laptop.
~Christian
- tlynch833Aspirant
Hi Christian,
Thanks for your comments. My driver is from Realtek. According to their website I have their latest driver. Should I be looking for another driver vendor?
I've got an older WN3000RPV3, purchased a few and love them. But I only use them on the devices that I either don't have WiFi cards on like my older PC... and I had to place one downstairs near another computer that we couldn't run a hardline too (also no wifi card).
They worked great on both my Windows 7 64-Bit PC and Laptops... but I hardwired them in. I plugged them in close to the machines, connected them directly to the main modem/router via WPS... and use a short patch cable. I honestly couldn't believe how stable and consistent these things were/are... I know they are meant for extending WiFi and should be able to spit up some WiFi for those hard to reach areas... but have you tried maybe just running a hardline from the WN3000RPV3 to your laptop just to see if it works? I know cables and wires are ugly... but whatever works heh.
