Lilybetty's avatar
Lilybetty
Wx6120 extender, says incorrect password
I have the right password, it keeps saying it’s incorrect, please help
I’ve done the reset and that didn’t work
  • plemans's avatar
    You have the EX6120?
    What firmware is on it?
    What router is it connected to?
    Did you set it up using wps or using the installation assistant?
    • Lilybetty's avatar
      Lilybetty
      Yes that’s the model , I don’t know what you mean by firmware ?
      Connected to a Vodafone router using wps as just got an error message when on computer
      Thanks
      • plemans's avatar
        firmware is the software (firmware) running the device.
        Vodafones wps function doesn't always work as it should.
        Try factory resetting the extender (push and hold reset for 7-15 seconds while extender is powered on), then reinstall it using the installation asssistant and NOT WPS.
