Daladier's avatar
Daladier
192.168.1.1 IP Address does not work.
192.168.1.1 IP Address does not work when trying to login and update the name of the wifi and/or password. I went to the routerlogin.net to search for support, but my serial number doesn't even register on the website. The Nighthawk App also does not locate my router/wifi.
  • plemans's avatar
    you have the c7800?
    If so, try 192.168.100.1
    If that doesn't work, what modem/router do you have?
    • Daladier's avatar
      Daladier
      Unfortunately, 192.168.100.1 did not work either (404 Not Found). 192.168.1.1 did initially work during set up, and then stopped after I got everything up and running.
      You are correct tho, I'm using the C7800. Nighthawk X4S-AC3200 Wifi Cable Modem Router
      • plemans's avatar
        Is it working?
        You could always try a factry reset
