cuse165's avatar
cuse165
Bypassing my DNS
I added a DNS that blocks adds when I am online I see every add there is so I tried another DNS same thing so the I tried opendns and same thing as the other two. My router is like bypassing my settings and not using any of my DNS. There is a page that tells you if you are connected to there DNS servers. One time it says I am and another time it says I am not. Anyone know anything or can help or know why my router is not using my settings and bypassing them?
  • Well first I would like to thank you for your rude answers and how you put your answer was uncalled for. If you had nothing to say dont answer my question. Dont take my question and pick it apart and be a smart ass  Next time I need a smart ass answer I know who I can contact.
  • > I added a DNS [...]
       To what?  What is the resulting DNS configuration after you "added"
    this (secret?) DNS server to whatever you had before (on whatever you
    had it)?
    > [...] My router is like bypassing my settings and not using any of my
    > DNS.
       Are you using some kind of computer/device?  What is its DNS
    configuration?  Is your "My router" "like bypassing my settings", or is
    your client device using something other than your "My router" for DNS?
       What is your "My router"?  (Model, hardware version, firmware
    version, ...?)
    > [...] There is a page that tells you if you are connected to there DNS
    > servers.
       Which page, on what?
    > [...] Anyone know anything [...]
       From that problem description, I don't know much.  As usual, showing
    actual actions with their actual results (error messages, LED
    indicators, ...) can be more helpful than vague descriptions or
    interpretations.  An accurate, detailed report of actual events would be
    much more interesting than your analysis/interpretation of the problem
    ("My router is like bypassing my settings", ...).
    • cuse165's avatar
      cuse165
      • michaelkenward's avatar
        michaelkenward
        Apologies for that. Most of the regulars here try to be helpful without being rude or to belittle people.
        Did you fix your problem?
        My approach to "ad spam" is to use a browser add-in that blocks ads.
        Messing around with DNS servers is a bit too complicated and open to error for my liking. I don't recall anyone else using that approach, so I doubt if you will find much around here on that topic.
