  • > Can this [...] be used to connect to the coax to connect to this [...]
       "the coax"?  _Which_ "the coax", from _where_?
       What, exactly, are you trying to do?  If you're asking whether a $5
    thimble-sized gizmo can replace a cable-TV modem, then the answer is no.
       I can't (yet) see your (second) picture. In-line images must be
    approved by a moderator before others can see them.  The time required
    varies.  Attachments have no such limitation.  Of course, attachments
    have their own one-per-message limitation.
    • Thomas1026's avatar
      Thomas1026
      The Coax cable coming into the house. What other coax would I be talking about? Oh yeah. The one coming out of my TV. I want to hook the TV to a router and send messages to Mars! I have family up there. I need to speak with! Puts adapter in box!
      • antinode's avatar
        antinode
        Guru
        > talking about? [...]
           How should I know?  With my weak psychic powers, I prefer to go by
        the information which you provide, not by my guesses about invisible
        stuff.
           My _guess_ was that you expected some $5 thimble-sized gizmo to
        replace a cable-TV modem, which suggested that you might not be very
        bright or well educated.  Your response to a simple question ("What,
        exactly, are you trying to do?") did nothing to refute that speculation.
           But feel free to provide some useful information, if you can.
    • antinode's avatar
      antinode
      Guru
      > I left two links there. [...]
         I followed them.  I didn't learn what you're trying to do from either
      of them.
      > [...] Why is that a hard question? [...]
         Because one of us seems to be unwilling/unable to answer a simple
      question:
      >    What, exactly, are you trying to do? [...]
         Each is still a mystery.  If you're waiting for me to make any more
      guesses, then you might have a long wait ahead of you.
      > [...] If you're asking whether a $5 thimble-sized gizmo can replace a
         That's my story, and I'm sticking to it.  At least until you switch
      from "smart" answers and insults to answers which convey some useful
      information.
      > [...] The adapter says it converts RJ45 to RF.
         No, it does _not_ say that.  "connectors" and "signals" are spelled
      differently for a reason.  If you tie an electrical extension cord
      to a garden hose, and then plug the extension-cord plug into an
      electrical outlet, you do _not_ get water out of the hose.
         Visit http://netgear.com/support , put in your (actual) model number
      (look for "Model" on the product label), and look for Documentation.
      Get the User Manual (at least).  Read.
         Do you have a modem of some kind?  Who/what is your ISP?
      > [...] I'm almost postive your not intellegent enough.
         That's "you're".  And "intelligent".
        Thomas1026
        Must be something wrong with this site because I copied and pasted a link to the!!!
        NETGEAR WNDR3400-100NAS Dual Band Wireless and Ethernet Router.  Then I copied and pasted a link to the F Female to RJ45 Male Coaxial Coax Barrel Coupler Adapter RJ45 to RF adapter found on eday and various other places. I also posted pictures of both. No one can seem to answer this question? Pretty simple question. Can it be fitted to the end of the coax inside the house which is where routers plug in and plug directly into ethernet on the back of the router. Because all it has is a ethernet connection on the modem/router. So instead of have a modem and a router. Just the router. Ive been around electronics and just dont see what this adapter would be used for? Interested to find out. What plugs an electric signal into an optical reciever?
