jaeholme
Jun 04, 2017Tutor
Configure Router for VPN
I'm trying to configure my router to connect to a VPN. I'd like to use VPN for any device on my network which is why I'm trying to connect my router to a VPN instead of the individual devices. The VPN service provider gave me "PPTP settings" (a username and login), L2TP connection username/pw/ and secret key, and lastly what appears to be a URL for the server (they gave me a global list, I assume I'd pick a local one). When I log into NetGear genie, I struggle to find a place to enter this information. I do not have a "VPN" option under "Advanced Settings" as some online instructions appear to indicate, so I'm trying to see if anyone knows where to enter this information in. Thanks in advance if anyone is able to provide any info.
Kind regards, Jason
Welcome to the community, jaeholme
The router doesn't support VPN hence you can't see any VPN feature anywhere on the screen.
You may probably have to use a different hardware in order to use VPN.
The only VPN that it supports is VPN passthrough.
Note: The model number WNDR3400v2 supports VPN Passthrough
- ElaineMNETGEAR Employee Retired
- William10aMaster
The only chonce is a third party firmware Have seen wndr3400v1's running dd-wrt firmware they seem to work ok may be the v2 version can run dd-wrt so well if it does you may be able to the vpn you want.
- jaeholmeTutor
Thanks everyone. Sounds like I need to get a new router that supports VPN, which is unfortunate.
