wbbest
Mar 06, 2018Tutor
connect old WNDR3400 router to new R7000P NightHawk
I upgraded my WNDR3400 Router to a new R7000P NightHawk Router to be able to stream video better. My problem is that now my older HP 6980 printer cant see the new router because as I have checked is the speed of the new R7000P. Question, is there a way to connect my old WNDR3400 to my new R7000P that would allow me to connect to my printer to my old router and be able to see in on my network?
finally got printer connected. Had to connect via ethernet, print a report page to get a IP address, open a browser and connect to that ip, then setup the wireless SSID and paraphrase, then disconnect the ethernet & print another report, getting a new IP, then set up that TCP/IP port for the printer.
> [...] my older HP 6980 printer cant see the new router because as I
Huh? What, exactly, do you think that the problem is? Do you really
think that your "new R7000P" is somehow incompatible with your old
wireless printer? Have you configured the 2.4GHz radio in the R7000P?
What, exactly, did you do? What, exactly, happened when you did it?
What you think it all means is of much less interest.- wbbestTutor
I disconnected my old WNDR3400 and connected my new R7000P. I have 2 printers connected wirelessly. my newest Epson XP830 Connected to new router with no porblem. When connecting my older HP 6980 my computer can't see the printer. I have tried connecting a usb to connect wirelessly as well as connected via usb and then changing to wifi but it never connects. There is no lcd pannel on this printer it is a older deskjet printer only. The blue wifi light is on but nothing connects
- wbbestTutor
