Adhamkhorshed's avatar
Mar 16, 2018
Connecting an N600 router to an adsl modem
How to connect an N600 router to an adsl modem ?
  • Adhamkhorshed's avatar
    Adhamkhorshed
    Mar 17, 2018
    Sorry by the way my modem router is a TP LINk  TD-W8961ND 300mbps Wireless N ADSL2
    It is not secret or something i just didn't want to mention any different product than Netgear :)
  • > How to connect an N600 router to an adsl modem ?
       Ethernet cable?
       "N600" is a speed, not a model number.  Ever helpful, Netgear product
    packaging emphasizes speeds like "Nxxx", but that's not the model
    identifier.  Look at the product label.
       "an adsl modem" is not a very detailed description of anything,
    either.
       Is this a new installation, or are you adding equipment to an
    existing installation, or what?  What, exactly, are you trying to do?
    In any case you may need to supply some actual information before you'll
    get much specific advice.
       For a Netgear device, visit http://netgear.com/support , put in your
    model number, and look for Documentation.  Get the User Manual.  Read.
      Adhamkhorshed
      My router model is WNDR3400 and I want to connect it to an already working adsl modem router
