Gloverjac
Nov 25, 2018Aspirant
Enable parental controls
I have an open dns account with parental controls, but my genie ap will not let me enable the parental controls. When I slide the enable button it thinks for a while and turns it off.
Try the newer firmware.
WNDR3400v3 Firmware Version 1.0.1.22 | Answer | NETGEAR Support
You may need to reset to factory defaults after the new firmware.
What hardware are we talking about here?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.Parental controls is among features that depend on what firmware you run.
- GloverjacAspirantV1.0.1.18_1.0.63
Yes, but what is the hardware?
Sorry, but life is too short to chase through all the Netgear hardware to find which firmware versions site on which devices.
Hint, fill on the bit on all messages that says:
Model (Recommended - Helps the community give the best answers)
You can also help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reasons. One of which is to get you more quickly to possible answers.
