dbakyle's avatar
dbakyle
Firmware V1.0.1.20_1.0.16 and Gene Access Stopped Working
This morning I upgraded my router to the latest firmware, V1.0.1.20_1.0.16.  This afternoon I tried to access the router page and it's no longer acting like it did.  When I try to use the Genie application I get various messages about not connected to the internet and can't verify my router firmware.  I'm actually able to get to the internet but just not access some of the sections of the app or webpage.  All the documents in help are on installation.  Is there anything documented on issues with the latest firmware?  Can I downgrade back to an older version?
Kyle
  • Yup. It is a pain. Screen grabs can help. (Alt+PrintScreen)
    Here's how I go about it:
    • save (backup) settings
    • flash firmware
    If that works and you see no problems, great. If not, and something doesn't work,you may have to reset the device to the default settings:
    • set to factory settings
    • retrieve settings from backup
    If that works and you see no problems, problem fixed! If not:
    • set to factory settings.
    • reconfigure everything
    If that fails, then I fear that you may have to flash back to earlier firmware.
  • michaelkenward's avatar
    michaelkenward
    Did you "factory reset" after the firmware update?
    This isn't always needed but it is the first thing to try if you have post-flash issues.
    Sometimes new firmware changes things that are not compatible with the older configuration.
    • dbakyle's avatar
      dbakyle
      I didn't do the factory reset.  While it's something I could try, it's not something I would look forward to since I've setup this router over the last year and it's working great, at least it was.  Resetting means I have to remember all the configuration changes that I made and remake.  Sounds like a weekend job to me.
        michaelkenward
        • flash firmware
  • I think that going to a full reset is a bit drastic. I updated to the same version of firmware for the R6400|AC1750 Smart WiFi Router about 25 minutes ago and got the same page. I've had similar issues with previous upgrades. In general, the routing information within the system can get confused after firmware updates.
    I went to my modem/gateway control panel and got the IP address of the Netgear router. My gateway is the typical 192.169.1.254 that so many gateways use, so the Netgear installation software changed the address of the router. I looked at the table of devices attached to my router and found the other IP. I entered the address of the router into the browser and the Netgear control panel popped right up.
    I knew then that it was just a matter of confusion within the routing within my setup. In this case it took no more than restarting my browser to get everything to work right. In the past, I once had to unplug my modem/gateway, R6400, and ethernet switch, restarted the gateway, restarted the R6400, and then plugged the switch back in, and everything worked fine.
    Doing a factory reset is a bit drastic. You have to re-enter a lot of information (or you can presave and reload the configuration). It may not be necessary to go that far.
      michaelkenward
      True, but it is sometimes essential, especially if the alternative is to spend hours trying to fix something that gets broken by the new firmware.
      The choice is up to the user. But they cannot really complain if they will not even try the reset to see if it fixes post-flash problems. I have presented a strategy that allows someone to see if a reset fixes a problem. If not, they can always go back to their earlier configuration, as you said.
