mostofa1's avatar
mostofa1
How could I limit my bandwidth?
The problem is my wifi users are getting bigger. And i immediately need to limit my bandwidth but i couldn,t . need extreme help. MOdel number WNR614 N300.
please
please
  • Retired_Member's avatar
    Retired_Member
    Sep 14, 2016
    You cannot limit bandwidth or figure out your users data that they used with netgear product's
    Retired_Member
    You cannot limit bandwidth with netgear product's
    You can limit user's time with other manufactures like ASUS  their FW allows you to control each user via MAC address
    • mostofa1's avatar
      mostofa1
      HOw do i figure out my users data that they used?
        Retired_Member
