spartan26
Aug 16, 2017Aspirant
Image will not upgrade
I have a WNDR3700v2 router. It is currently on firmware V1.0.0.32. I am trying to upgrade to the latest which I have downloaded (WNDR3700v2_WNDR37VVv2-V1.0.1.14.img). I keep getting the following error " this firmware file is incorrect, please get the firmware image associated with this product". I have tried other images with the same result. Anyone know how to fix this so I can get my firmware upgraded?
thanks
Marc
> There is no firmware 1.0.0.32.
I'm sure that you must be right, but:
https://kb.netgear.com/22083/WNDR3700v2-WNDR37AVv2-Firmware-Version-1-0-0-32
Boy, that Google thing is a miracle.
Perhaps there's a reason that 1.0.0.32 is no longer available.
I know nothing, but you might try to get an answer from Netgear,
although that may be difficult and/or expensive. Failing that, there's
a TFTP scheme which may be able to force firmware of your choice down
its throat, but there is some risk of inappropriate firmware disabling
the gizmo.
spartan26 wrote:I have a WNDR3700v2 router. It is currently on firmware V1.0.0.32.
There is no V1.0.0.32 firmware for the WNDR3700v2.
Maybe it is a different flavour of WNDR3700. You should find the model number on a label on the back.
- spartan26AspirantI have double checked and it’s firmware is 1.0.0.32 and the model number is WNDR3700V2
This is the support section for that device:
>> Click here >> WNDR3700v2 | Product | Support | NETGEAR << Click here <<
Have you tried using the modem's browser interface to tell it to find the newest firmware?
The manual (see link above) explains how to do this.
