ant's avatar
ant
Prodigy
Jan 30, 2020
Is it possible 2 change Netgear R6300 v1's router's guest WAP's channel?
I don't see an option to change it. Only on non-guest sides. This is using the (lat/new)est firmware v1.0.2.80_1.0.59.
Thank you for reading and hopefully answering. :)
  • > I don't see an option to change it. Only on non-guest sides. [...]
       I'd guess that that's because there is no way to do it.  On these
    routers, the "guest network" is implemented as a set of firewall-like
    rules to restrict "guest" clients; there is no separate "guest" radio
    with its own radio channel.
    • ant's avatar
      ant
      Prodigy
      Ah, thanks. :)
