Koyoo
Apr 24, 2017Aspirant
Netgear R6100 internet
So I was watching a video and suddenly my router stopped working properly on my phone, for some reason the internet is terribly slow on everything besides my tablet and I have no clue how to fix it. I turned off and on the router, unplugged the router, disconnected the wi-fi from my tablet, and turned off all my stuff for nearly 24 hours and it's still slow.
I use the 5ghz version, but now that doesn't even load.
2.4ghz ver loads but takes forever to load something simple.
And it certainly isn't my internet going bad because I ran a speed test and I get 36mbps.
Hi Koyoo,
You can try resetting the router for isolation. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Koyoo,
1. What is the firmware version of the router?
2. Are your other devices working fine (wired and wireless)?
3. Does the issue persist only on your phone (please indicate brand and model)?
4. Have you tried changing the wireless channel? If not, check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/24095
http://kb.netgear.com/app/answers/detail/a_id/23783
5. Have you tried resetting (factory reset) the router?
Dexter
Community Team
- wcalifas831Prodigy
You can alwasy try a hard reset on your router, did you give that a try?
Hi Koyoo,
Dexter
Community Team
- KoyooAspirant1. I can't find out the firmware as it's not letting me login to netgear genie.
2. No, the only device that seems to work with the router is my Kindle fire 7 tablet
3. It persists on all the phones currently here. LG G4, LG Ultimate 2, and a Samsung s4
4. Can't change the channel as it isn't allowing me to login at all
