allwowth
Mar 05, 2017Aspirant
Netgear router not accepting correct primary and secondary DNS settings
I'm trying to setup OpenDNS.. When I put in the OpenDNS primary (202.67.222.222) and secondary (208.67.220.220) settings and click "Apply" the settings shown are different.
Primary: 195.67.222.222
Secondary: 195.67.220.220
Does anyone know how I can get the correct settings in?
Note: I do get on the Internet with the "195" settings.
I have tried to change this many times, but, it never shows the "208" first setting, always "195"
Elaine:
I did the 30-30-30 reset. Still the same problem. I'll purchase a new router, Netgear, of course.
Many many thanks for all the help.
Gus
- ElaineMNETGEAR Employee Retired
Welcome to the community, allwowth
What's the exact model number of the NETGEAR device?
Did you enable OpenDNS feature or you're simply using the OpenDNS addresses?
- allwowthAspirant
Elaine:
Thanks for the post.
The model number is WNDR3700 V2, (N600). I appreciate any advice you can give me.
Gus
What's the firmware installed on the router?
Do you have the latest firmware installed?
If not, update the firmware or re-upload it then factory reset the router.
