JLEVAVASSEUR's avatar
Sep 13, 2015
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
  • I just installed it and now my laptop will not reboot!!!!!! Dont do it!
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      Kindly contact our support team.
      They should be able to give you the beta.
      It supports both, El Capitan and Sierra OS.
      Dimyas What was the version provided to you?
      • Dimyas's avatar
        Dimyas
        Forget it! You guys have DROPPED THE BALL. Why would I "try" anything else from NetGear!!!!??????
    • ElaineM's avatar
      ElaineM
      cleudio Contact support and tell them the beta software for the USB Control Center Utility for your Mac computer.
      • solidairs's avatar
        solidairs
        Tutor
        Hello Elaine, seasons greetings. I would like to test the USB Beta software but find it impossible to make this request via your customer support. Could you please provide a link to download the required files - either here on this forum ir direct to my associated email address.
        Many thanks.
