JLEVAVASSEUR
Sep 13, 2015Tutor
NETGEAR USB Control Center utility for MAC OS X El Capitan
NETGEAR USB Control Center utility v 2.22 is not compatible with MAC OS X El Capitan, where to download or make NETGEAR USB Control Center utility with the new MAC OS X ?
Hello All,
You may now download the official release of the USB Control Center Utility for MAC OS 10.11 and above from the link below.
- cleudioGuidewhere is the link of this update?
Hello Elaine, seasons greetings. I would like to test the USB Beta software but find it impossible to make this request via your customer support. Could you please provide a link to download the required files - either here on this forum ir direct to my associated email address.
Many thanks.
- DimyasAspirantI just installed it and now my laptop will not reboot!!!!!! Dont do it!
- DimyasAspirant
Forget it! You guys have DROPPED THE BALL. Why would I "try" anything else from NetGear!!!!??????
- This is turning farcical, net gear are so far behind that this thread started asking for the app to run on el capitan but now we've moved onto Sierra! So which version is the beta for?
- tuckerm2AspirantToo little too late unfortunately. I had to buy a new printer instead.
Absolutely shocking understanding of customer needs for a large user base. Completely soured my experience of Netgear products. - cleudioGuideif there is a beta, because it is not posted the link to give the opportunity to those who want to download it? I do not understand this conspiratorial policy by netgear. short enough to post the link to the beta right away and ask those who want to test you can do.This put the question without the link seems a further mockery ... after they have already passed two years
- Drummy82AspirantI will as long as it won't make my computer explode :)
- cleudioGuidewhere you can download this beta?
- daraghfiAspirantJust to be clear, I'll never buy netgear again, and recommend others don't either.
- daraghfiAspirantI presume it doesn't work with Google wifi. By the way, I got a wifi extender from netgear, and also consider it a waste of money - wouldn't even give it to someone I don't particularly like.
- Drummy82AspirantI'm looking for this solution, but haven't found it yet. This post was 6 months ago. Anything fixed?
