geofmill's avatar
geofmill
Only one router
Have 6220 modem-router-wi-fi (wi-fi disabled). Using Orbi system to distribute Wi-fi in house.
Is there a way to disable D6220 router and use the more updated Orbi router?
Everything updated to latest firmware.
Thanks.
  • > Yes, using dsl modem. PPPoE.
       Ok.  Then you should be able to configure the D6220 as a modem-only,
    and configure the PPPoE credentials on the Orbi router (whatever its
    model number might be).
    > Since I updated entire Netgear system 3 days ago, all 6 pieces are up
    > to date.
       "up to date" tells me no more than "latest" did.  Any (unfortunate)
    future readers will find it even less helpful.
    > I already checked documentation and there is no listed method for
    > disabling the router.
       Which "documentation"?  When I looked at the D6220 User Manual, I
    (easily) found the section whose heading I quoted above.
  • > Have [D?]6220 modem-router-wi-fi [...]
       Connected to what?  Are you using its DSL modem?  PPPoA or PPPoE?
    > [...] Is there a way to disable D6220 router [...]
       It depends, but you might visit http://netgear.com/support , put in
    your model number, and look for Documentation.  Get the User Manual.
    Look for "Use the Modem Router as a DSL Modem Only".
       As always, actual version numbers would be more useful than your
    opinion of what's "latest" today.
  • Thanks for reply’s.
    Since I updated entire Netgear system 3 days ago, all 6 pieces are up to date.
    I already checked documentation and there is no listed method for disabling the router.
    Looking forward to more input.
    Thanks.
    • antinode's avatar
      antinode
      Guru
      > to date.
