helponhand
Oct 19, 2021Aspirant
Problems buying from Netgear UK
Purchased a WAX214 through Netgear.co.uk & received a GS324 switch. I tried to contact them multiple times, but they seem either not interested in taking back the wrong item they sent or refunding me.
How can I get hold of somebody there that actually cares that they messed up the order?
Looks like Netgear farms out the "store".
Check the bottom of this page:
Netgear UK Store | Buy Wifi Routers, Mesh Wifi & Range Extenders.
Who or what is Exertis UK Ltd?
"©1996 - 2020 NETGEAR ®" is a bit worrying.
Did you find this?
Contact Customer Service by email on– netgearstoresupport@exertis.co.uk
On this page:
Frequently Asked Questions | Netgear UK Store
Netgear has set up a community forum specifically for the Business Wireless products. Most of the people who watch that forum are more likely to have experience with business wireless products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Business-Wireless/bd-p/business-wireless-for-businessPlease use this link to the main forum product list to review and choose where to make your posts.
Thank you.- helponhandAspirant
FURRYe38 wrote:Netgear has set up a community forum specifically for the Business Wireless products.
Thanks for the suggestion. I will head over there.
My problem isn't how to use the product., or a fault. It is the Fact that Netgear UK sent the wrong product to me and are not interested in getting it sorted.
I hate to be the bearer of bad news, but Netgear support is virtually non-existent. It's practically a ghost town in this regard. Good luck trying to get hold of anyone at Netgear.
Did you find this?
On this page:
Yup,
I found out that netgear.co.uk is Exertis UK Ltd and they are totally unresponsive.
Tried calling and emailing and got nowhere.
If you live in the UK buy from Scan.co.uk not netgear.co.uk as you will actually get support if anything goes wrong.
I have never tried buying from Netgear. I have my own favoured supplier. Preferably not Amazon.
I have used Scan in the past but I recently needed a motherboard that seems to be unavailable here and I ended up buying from a German outlet. (Yes, they do still supply to the UK!) Just as quick as many UK suppliers.
