MSRadell's avatar
MSRadell
QOS settings not staying set on R6400
I'm setting up my R6400 that I just purchased and everything is going to lose except it doesn't appear that the upstream QOS setting I want for IP Phone is staying set. I go through the advanced menu and click the button in front of IP Phone then click enable but when I go back to look at the settings the button from the IP Phone is again unchecked. What do I do to get the rotor to accept QOS for IP Phone?
  • Hi @MSRadell,
    Once you have checked the box to Enable Upstream QoS then all the QoS rules will be applied. The radio button indicator will only be highlighted if you select it to edit or delete a certain rule.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi @MSRadell,
    Dexter
    Community Team
    • MSRadell's avatar
      MSRadell
      Thanks, after playing around with it some more that's kind of what I figured but it's nice to get confirmation of that.
