TeamT
Jan 17, 2017Star
R6220 stop to respond to DNS queries.
Hi,
My R6220 router with firmware V1.1.0.34_1.0.1 stops to respond to DNS queries aproximately every 4th day. Restart of the router fix the problem temporarily. I have saved WireShark captures to prove my case.
Manually configuring the clients DNS to something else than the router's IP-address resolves the problem but is not a good long term solution. AND you can't configure the router to supply an alternative DNS-server like 8.8.8.8 to bypass the router.
Let me know if you would like to see the WireShark capture files and logfile.
Please Netgear, advise.
Kind regards,
TeamT
Hi,
My router has been OK for 27 days now. There are good reasons to assume that the bug has been fixed.
Kind regards,
TeamT
- DexterJBNETGEAR Moderator
Short status as I have discovered that there are multiple threads on this issue on different router models.
A support case was opened on 21 January 2017. I have since then provided my assistance to Netgear:
- I have provided Netgear with WireShark capture files and logfiles to prove that DNS really stops to respond
- Different client and router configurations have been tested without success
- Netgear have via remote downloaded the config file and downgraded the firmware
- The hardware have (to my surprise) been replaced to eliminate hardware related problems
- Screenshot of status page have been sharedThe support case is now with “team” and “engineers” within Netgear. I am slowly loosing patience but willing to give it a few weeks more. (The teenagers are begging for a new router and by now prepared to pay for it :-) )
My additional findings are:
- I have an indication on that the issuse is traffic dependent as the router did work for 10 days when we were on vacation
- Disconnecting the WAN cable for a few seconds clear-out the problemMy best guess is a memory leak or dead-lock situation in a DNS related process. Curious on what processes are restarted when you disconnect/connect the WAN cable.
Kind regards,
TeamT- shofixtiTutor
Have you had any updates on your case?
This bug just started biting me this morning.
On my PCs and such it's easy enough to bypass their broken DNS, but that doesn't work as well for mobile devices, guests, etc.
If they can't fix this, time for a new router I guess.
- TobroInitiate
I have the exact same issue and see this problem going back years? How is that possible? If you aren't using any parental controls why does the netgear router have to act as a passthrough DNS server. It should be assigning the manually assigned DNS entered on the WAN configuration, not it's own IP address. Seems like a really simple solution.
TeamT, hope they get an update to you.
Update:
Got a new firmware with some troubleshooting capabilities on the 28th of April. Installed it and the DNS bug showed up again at 1st of May.
I was instructed to start/restart the domain name relay daemon in the router by sending a command to the router via a web browser link. After restarting the daemon the router worked fine again. Issue is now back with engineering again.
My view is that this proved that the domain name relay daemon in the router fails (is killed or hangs) due to a bug. Very strange that the bug hasn't been solved as several users have reported problems during several years.
/ TeamT
Update:
Got a new firmware to log the domain name relay deamon. Were able to get a log when DNS hangs. Log is now with enginering.
Had a quick look at the log. Socket numbers seems to increase for some reason and after socket number 1023 DNS stops. Disconnect / conect the WAN cable restarts the domain name relay domain and it works fine again.
/ TeamT
- Seth21GuideHave the same issue. Internet goes out, all I have to do is renew the DNS and everything is good for another 1-4 days.
This is actually my second router. I sent the first one back and got a 2nd. Both have the issue. I downloaded the latest firmware a few days ago and have had a failure already.
I'd love to ditch the router and move on but I can no longer return it and I feel bad selling a defective product to someone else.Seth21 just curious on how you "renew the DNS" to make the router work again. I have ony been able to find two ways to clear out the DNS fault.
- Restart of the router
- Reconnect / Connect the WAN cable (saw in the dubug log that the Domain Name Relay Deamon restarts when you disconnect / connect the WAN cable)
/ TeamT
- Seth21Guide
Login to router at 192.168.1.1; go to advanced - then connection status and click 'renew'. It is nice because you can do it from your desktop as my router is downstairs and my office upstairs.
I'm about ready to send this router out to pasture and just move on.
- grindaxGuide
Has there been any further update to this issue? It looks like there hasn't been any new firmware made available to the public for this router for quite some time.
I recently ordered the Netgear R6220 from Amazon and it will arrive tomorrow. In the meantime I've been reading forum threads such as this, and now I think it might be wise to simply return it for a refund once it arrives.
- shofixtiTutor
Candidly, I'd return it. I'd return mine if I could, but my window closed before I noticed this bug.
There is a hero on this thread working with Netgear Engineering to try and fix this, but it's been a months-long process for a bug that's just ridiculous in the first place.
In addition, having used the product for a while, I'm pretty convinced there are better routers out there for equivalent money. YMMV of course, depending on what kind of deal you got on the product.
- grindaxGuide
Thanks shofixti, I think I will heed your advice. There's no point keeping it in the hopes that Netgear will someday fix the issue, especially as it has already been so long since the issue was discovered. It isn't a new product, and still to this day there has been no fix forthcoming. I do wonder how such a critical bug can be left for years without getting fixed, and how Netgear can continue selling a known-defective product all this time. A router needs to be stable and reliable, without the need to keep restarting the thing.
I ordered it because it was available from Amazon UK for only £39.98. But if it can't be relied on, then it isn't worth anything to me. I'll need to connect some alternative product to my network.
Update:
Got a message a week ago that Netgeer engineering now plan now provide a new debug firmware.
My router has for some reason decided to be more stable and has now been running for 10 days. Socket count is now, according to the log file, at 800. My best guess is that it will reach 1023 and fail on Sunday ;-)
Now 5 months since ticket was registred.
/ TeamT
Hi,
Just back from vacation. A short status update:
Got a message from Netgear. Looks like plans on a second debug firmware has been canceled. Netgear is now requesting same logs and WireShark captures that they already have got. To sum it up. I see no progress what so ever.
In a bad mood. Need kudos - or maybe a new router!
/ TeamT
- joshuagreenInitiate
I also have the same issue. Hope that these solutions may work
- vhovarInitiate
I have had my R6220 for almost a year now with no issues. I was looking through the configuration last week when I added an IP Camera and enabled DynDNS. It seems that after I did that and added the camera I started having this exact problem. I've turned DynDNS off but now continue to have the problem with the DNS not responding until I reset the router. This happens every night and has started happening during the day. I'm thinking about trying do do a factory reset and reload the current firmware to see if this might help resolve the issue.
Hi,
I tried everything without success. Netgear even arranged a hardware swap!
I suggest instead that you try to issue a ticket and a request to test the beta firmware R6220_v54_dnrd.img My router have now been stable for more than 10 days.
Kind regards,
TeamT
Hi,
Kind regards,
TeamT
- PatriciaMcCAspirantExact same here. Worked for a year, then started failing after adding an IP camera (Armcrest). I didn't enable DynDNS at any time. I have to reset the router every morning. Now it has failed in middle of the day. I might try static IP on camera and maybe even point its DNS elsewhere.
