Wolfangovich's avatar
Wolfangovich
R6300 Power Adapter replacement?
For a replacement power adapter, I understand it is a 12V 5a, but what is the polarity on the end? Is it Negative inside or Positive inside?
TIA.
    A quick check of four Netgear adapters I have lying around says positive inside.
  • michaelkenward's avatar
    michaelkenward
  • > [...] I understand it is a 12V 5a, [...]
       For an R6300 plain/v1, that seems to agree with the documentation.
    (The R6300v2 seems to be more efficient.)
    > [...] what is the polarity on the end? [...]
       Doesn't the label on the adapter show this?  If not, then look
    closely at the product label on the router  If that fails, then visit
    http://netgear.com/support , put in your model number, and look for
    Documentation.  Get the User Manual.  Look for "Label".  (Also
    interesting: "Technical Specifications".)
    • Wolfangovich's avatar
      Wolfangovich
      1 I checked all documentation
      2 little hard to check the adapter if I am replacing it
      3 the router does not show this information, thus the question in the first place
      4 checked their entire site, answer is not found on there, thus the question
      • antinode's avatar
        antinode
        Guru
           Define "all".  Does that include the User Manual?  Where there's a
        picture of the product label?  Which shows the polarity of the power
        connector?
           Are you replacing it because it's defective or because it's missing?
        > first place
           Is the product label missing from the router?
        > 4 checked their entire site, [...]
           That's just silly.  And you don't need to check "their entire site",
        only the User Manual for the R6300.
        > [...] answer is not found on there, thus the question
           I found it there, following the instructions provided:
              http://www.downloads.netgear.com/files/GDC/R6300/R6300_UM_18Jun12.pdf
           Look at page 11, "Label", "Figure 4. The label shows unique
        information about your router", upper right-hand corner.  Some
        magnification might help.
           It's not complicated.  Try a Web search for these keywords:
              lead horse water drink
