thedoctor10925's avatar
May 20, 2018
R6300v2 "online" night does not light up and no internet
R6300v2 was working great up until yesterday. Today the internet/online light no longer lights up and I cannot connect to the internet. Modem is working fine. Can connect to WiFi but no internet access. Suggestions?
  • DexterJB's avatar
    DexterJB
    May 23, 2018
    Hi thedoctor10925,
    1. Have you tried changing the cable connecting the modem to the router?
    2. You can also try doing a loopback test to check if the Internet/WAN port is working. This link may help out.
    Dexter
    Community Team
  • michaelkenward's avatar
    michaelkenward
    Have you tried rebooting the whole network in the correct order?
    • Turn off and unplug the modem.
    • Turn off the modem router and computers.
    • Plug in the modem and turn it on. Wait 2 minutes.
    • Turn on the modem router and wait 2 minutes.
    • Turn on the computers.
    • thedoctor10925's avatar
      thedoctor10925
      Thanks for the reply michaelkenward. Yes, I tried the recommended procedure twice.
      Still have no access to internet via the router.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi thedoctor10925,
        Dexter
        Community Team
