Jleake1989's avatar
Jleake1989
R6350 -ac1750 smart WiFi
Does it support vdsl?
  • > R6350 [...]
       It's a router, not a modem+router.  It neither knows nor cares about
    ADSL, VDSL, or any other DSL.  (Or cable-TV, or fiber, or ...)
       There is some fine print, however.  If your DSL service uses PPPoA,
    then a combined modem+router may be required.  PPPoE should be ok,
    however.  What did you intend to use as a modem?  Who's the ISP?
  • > R6350 [...]
    • Jleake1989's avatar
      Jleake1989
      That’s what I figured out. I thought it was a router/modem. So I will be going with a different model.
      Thanks for the help
  • what do i need to do get my netgear modem to see my router?
    • michaelkenward's avatar
      michaelkenward
      Start by telling us what the modem is and if you really do own an R6350 or have just joined in on a conversation started by someone with that hardware.
      If you do have an R6350, a good place to start is with the Quick Start guide. Find it here:
      >>>R6350 | Product | Support | NETGEAR<<<
      Go through it and tell us where things go wrong, or bits you don't understand.
      By the way, as you have joined in on an older discussion there's a chance that the official support team will be too busy following new stuff to find your message. It is usually better to start your own fresh discussion if you want their attention.
      Just click the Create a New Discussion button at the top of this section's front page:
      R6000 Series AC WiFi Routers - NETGEAR Communities
