k6's avatar
k6
Guide
Dec 30, 2020
R6400 Missing Firmware Update
Got the email about the important firmware update, but there are no updates available when I checked through the router page.
My current firmware version says "V1.0.4.84_10.0.58," when I looked online for a manual patch the latest I see is "1.0.1.68 - Hot Fix."
Do I install the manual patch or wait for the router page to release the update? Confused since the current seems to be a more up-to-date version or wrong firmware.
  • I did the update yesterday via admin router login, now my internet is really slow. 7Mbs vs 40-50 Mbs normally.
    Wondering if it was a malware email.
    • k6's avatar
      k6
      Guide
      Doubt it since it's an official email and a breach that severe would have been addressed by now.
      • mtnroads's avatar
        mtnroads
        Thanks.
        Did another router reboot and the speed is back to normal (50 Mbs).
        V1.0.4.106_10.0.80
  • Anyone able to help with this issue?
    Can't contact support since my router is older than 90 days...
    • mtnroads's avatar
      mtnroads
      Are you unable to login to the router directly, from a browser, using admin? When I did that, I simply used the UPDATE function and it went out and found the correct update (listed above).
