Blitzcannon
Dec 21, 2017Aspirant
R6400 port forwarding help
I’m trying to portforwars to play Minecraft with friends but it doesn’t work I don’t know why. I literally entered in the port in the portforwarding tab and it doesn’t work. So I don’t know if there i...
- Dec 27, 2017
Blitzcannon
My IPV4 address starts with 192.168..... and after researching i know that it is a private address from what other forums say but i dont know how to change that in the settings for my specific router
TheEther
Dec 21, 2017Guru
Well, your R6400 is probably connected to a modem. Do you have the model number? That will help us determine if it has a router.
- BlitzcannonDec 22, 2017Aspirant
the serial number for the router is 4B35647AA345C And the serial number for the modem it is connected too is 275736835 (it says Cisco on the outside if that helps)
- TheEtherDec 22, 2017GuruPlease provide the model number, not the serial number.
- antinodeDec 22, 2017Guru
> the serial number for the router is [...]
The model number was all the useful information about the router.
> [...] the serial number for the modem it is connected too is 275736835
Swell. Now, if Cisco made only one product, then I might be able to
find a manual for it. Sadly, that's not the case.- BlitzcannonDec 22, 2017Aspirant
entirely my bad, i wrote the serial number not the model number
the model number for the cisco modem is DPC3216
