gian1312
May 26, 2017Aspirant
R6400 Weak Power, low range
Hi all I have bought the R6400 to reach all rooms in my house. Sadly, the router from the internet provider has more range and power even if it is standing a floor below. Furhter, the R6400 is un...
- May 26, 2017
Thank you all for your answers.
In this case Netgear will have to replace it.
Have a nice evening
William10a
May 26, 2017Master
Have you tried to scan wifi spectrum around you to how many other routers wifi that may be interfering with your router?
Possible that you have a bad router with the wifi power set to full it should cover a reasonably size home.
gian1312
Thank you for answering.
Yes, I did. But we live in a small house. So there are only two weak neighbour wlans. On the 5 GHZ there is no channel used, just ours.
On the 2.4 the netgear router has a channel and its neighbour channel for its own.
Best Regards
- William10aMay 26, 2017Master
If a bad router you could try to support for a replacement or return to place you get the router if still their replacement time frame. Sounds like the router has a problem you did disable the modem/router's from your isp or placed into a bridge mode if you can access it's gui.
- gian1312May 26, 2017Aspirant
Have a nice evening
