gian1312
May 26, 2017Aspirant
R6400 Weak Power, low range
Hi all I have bought the R6400 to reach all rooms in my house. Sadly, the router from the internet provider has more range and power even if it is standing a floor below. Furhter, the R6400 is un...
- May 26, 2017
Thank you all for your answers.
In this case Netgear will have to replace it.
Have a nice evening
William10a
May 26, 2017Master
If a bad router you could try to support for a replacement or return to place you get the router if still their replacement time frame. Sounds like the router has a problem you did disable the modem/router's from your isp or placed into a bridge mode if you can access it's gui.
gian1312
Have a nice evening
