dems's avatar
dems
Router R6020
Hello,
I have some issue to connect Wifi module to the router. I would interested to know if there is way to retrieve the logs from the router.
I need it to understand why the connection is rejected.
Best Regards,
  • plemans's avatar
    Page 101 of the manual goes over access the logs.
    https://www.netgear.com/support/product/R6020.aspx
    we can also potentially help but we'd need more info that what you've provided.
    what modem/gateway is it connected to?
    What device are you trying to connect to the wifi?
    What error are you getting on the device?
    Firmware on the router?
    • dems's avatar
      dems
      What modem/gateway is it connected to?
      -> Router R6020
      -> It is an embedded board
      -> [WLAN access rejected: incorrect security] from MAC address ..........
      Firmware on the router? -> V1.0.0.40
