Sarevian
Aug 08, 2015Aspirant
Trying to disable WPS (bringing the topic to the top of lists again)
So - I've had my R6300v2 for a day. I've fiddled with most settings and I'm happy that for most things it'll do what I need. ALL EXCEPT WPS! A week ago I ordered a D-Link which shocked me whe...
- Aug 11, 2015
You don't have a checkbox to disable WPS in Advanced Wireless Settings?
doraemon
Aug 11, 2015Prodigy
- SarevianAug 15, 2015Aspirant
Thanks for the reply.
I can see exactly the settings you have screenshotted.
Turning the first checkbox on or off does not disable WPS.
The others just adjust settings of the already enabled feature.
[Replying to myself to "show" my imperfect solution.]
I think I saw this on another post so I don't claim originality.
Turning off SSID broadcast disables WPS. ..... (as far as I can tell)
I still have both 2.4GHz and 5GHz wireless active but (I guess) WPS doesn't work when there's no name (SSID) to start things off.
The two guest accounts/wireless still show up but WPS doesn't apply to them.
Pressing the WPS button causes the LED to flash very fast for a second or two.
Not ideal at all but it works after a fashion.
I'd still like the NetGear developers to add a simple WPS enable/disable checkbox in a future firmware update.
