Sarevian
Aug 09, 2015Aspirant
Trying to disable WPS (bringing the topic to the top of lists again)
So - I've had my R6300v2 for a day. I've fiddled with most settings and I'm happy that for most things it'll do what I need. ALL EXCEPT WPS! A week ago I ordered a D-Link which shocked me whe...
- Aug 11, 2015
You don't have a checkbox to disable WPS in Advanced Wireless Settings?
HitPoint
Oct 20, 2015Aspirant
Why do you need WPS off completely when you have to physically hit the button anyway to allow access. The only way a bruteforce can get through your router is through the PIN, which when disabled removes any security threats through WPS... I think the only thing that might be an issue is if you have a guest/family member in your household that you're trying to prevent access and they're somehow getting to the WPS button, then I would understand your dilemma to a point, but still there is ways of preventing such acts with a few simple steps ---
1. Move the router to your room and hide it from plain sight
2. Ask your guest politely to leave the router alone
3. Stop being paranoid, no one is trying to hack your router (circumstantial).
WPS itself is a security feature to allow other means of supplying network access without SSID broadcast (most secure feature on the router). Netgear giving the option to disable WPS completely would only make security worse for you and your network. Not to mention WPS itself is built into the router without a circuit switch so that option is not possible in the first place unless it was added with newer models.
Again, if you want total physical control over security from within your network then you need to take the necessary steps I listed above. It's not Netgear's problem to fix your networking dilemma within your household, that's between you and your family/guests. Anyways, I hope you get through your issue and hopefully find eventual peace. I'm a network security nut myself and take pride in securing every hole and every vulnerability.
-Mike
TheEther
Oct 21, 2015Guru
I am in agreement with you about physically securing your router, but you lost me with your assertion that WPS is the "most secure feature on the router". It has been well known since 2011 that the WPS PIN is fundamentally insecure. There are only 11,000 combinations for the PIN. (Source: Wikipedia). Moreover, devices that provide WPS must support PIN as a baseline requirement! I suppose we should be thankful that Netgear provided options to protect the PIN against bruteforce attacks as well as disable the PIN, but why not offer the option to disable it altogether?
The best way to secure Wi-Fi is to use WPA2 with a strong password. It should be long and it should include upper and lower case letters, numbers and special characters. WPS was conceived to simplify the task of joining a Wi-Fi network. That's a noble idea, but unfortunately the design is broken.
