steveincolorado's avatar
Jan 02, 2015
WNDR 4300 loses 2.4GHz Radio daily
I purchased a 4300 router in November of 2013. Soon after purchase I had to reboot the router daily to keep the wireless working. Tech support provided a new firmware update which solved the problem. Fast forward to December 2014 and the router started dropping the 2.4GHz band radio weekly. Now I had to reboot daily or I lose those devices that lack a 5GHz radio. This is very frustrating, I can't seem to keep Netgear routers up and running.
My router's current firmware is 1.0.1.60 and when I do a check for new firmware the router reports No new firmware version available.
I'm at my wits end with this router which replaced a WNDR 4000 that had similar issues then died altogether in under 18 months. There has got to be a way to keep my Router up and working.
Anyone possibly has any ideas on how to correct this issue?
Thanks in advance.
Steve
  • The issue was never about the Cable Modem. I fixed the issue by swapping out the Router for someone else's and so far it's been rock solid.
    Thanks anyway.
    Steve
  • I am having same exact problems, why? I did firmware update to latest version but still lose wifi radio every single day. The Genie "can see it" my 2.4 and 5.0 wireless but I can't connect. I am tired of daily reboots and I just bought this router because Netgear was recommended. My prior router ( a Linksys) worked flawlessly for about 6 years before it died. :confused:
  • UPDATE:
    Now I'm having to power cycle the router ever 90 minutes. I lose connectivity on both radio's (2.5GHz and 5.0GHz) as well as over the Ethernet LAN ports.
    This router powers my phone besides my regular Internet. I need this to work and work reliably. The router is only 13 months old.
    Any suggestions?
    Thanks
    Steve
